My Files randomly refreshing and freezing
  • Device model (e.g. 2020 iPad Air 4th Gen): Macbook Pro 16 2021
  • Version of operating system (e.g. macOS 14.4.1): 15.4
  • Version of djay (e.g. 5.1.2): 5.3
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Reloop Mixon 8 Pro
Summary of the issue:
My Files randomly refreshes all folders causing folder browsing being frozen for 10 seconds. Other functions seem to slow down too. iCloud is turned off.
How to reproduce the issue:
Nothing, files just refresh a few times every hour. Doesn’t matter if music is playing or not.
Hi @Turboviiksi, welcome to the Community! This sounds like unexpected behavior. Can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
Hello! It’s been nearly a week since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks![
It hasn’t happened now for a few sessions, but previously it did happen multiple times. My only guess is that some other program was modifying some files causing it to refresh the folder.
Thanks for the follow up @Turboviiksi
