After spending 50 dollars on the app I open it and there is no music from my iTunes I tried refreshing my library nothing happened I Checked off the share my music thing and nothing happened. I need help asap or it will be a waste of my money
Hey Noah Joffe,
sorry to hear about your experience so far but I am sure we will find the root of the problem:
Please try the following:
- Quit djay Pro
- Open up iTunes > Preferences > “Advanced”
- Set a check mark to “Share iTunes Library XML with other applications” and click “Ok”
- Launch djay Pro
See if it is working now!
Cheers,Lukas E.
