The iTunes playlist is in the wrong order on OS DJAY PRO. The playlist order is correct in iTunes and it shows up perfectly on iTunes on my iOS devices and djay in the iOS devices
macOS Catalina Version 10.15.1
MacBook Pro (15-inch, 2018)
2.9 GHz 6-Core Intel Core i9
I wanted to clarify, its NOT the songs that are in the wrong order, it is the actual playlist. Every time I edit one playlist on itunes, it shows up at the bottom of the playlist on DJAY.
Anything? This issue makes it really hard for our team to find playlist when doing events. Making your software a joke!
It’s been over a week and still no response on a solution?
Lukas, come on brother, we have the same name =) Any chance you can help or solve this problem?
Hi Lucas,
Can you share the macOS version you are working with?
Cheers
Hi Lucas,
Could you please check if the playlists are displayed in the same “wrong” order in Garage Band as in djay?
Thank you in advance.
