I couldn’t find an existing thread. I’m using the German version on iPad and the recordings are named: Aufnahme dd.mm.yy(…).
This results in a weird sorting when the files are sorted alphabetically. e.g. 01.10.2024 02.01.2023 17.09.2024…
If you’d change the timestamp to be yy-mm-dd all recordings would automatically be sorted in the right order.
Thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
It’s the Japanese date format, used often in IT to guarantee things are in listed in chronological order.
I’ve used it for everything I do, including playlists for years.
