It would be great if djay Pro could be updated to natively work with the new Pioneer DDJ SB 2 that just came out. The DDJ SB 1 integration was pretty solid and the DDJ SB 2 has a new Pad Trans effect that seems cool. Thanks.
I’m sure you’ve found out by now. But if you haven’t done the latest software update, it works natively! And yes, the Trans effect. It’s rock solid
