I just downloaded djay Pro for Windows 10, everything is working allright so far but the only problem is that my natively supported MIDI controller isn’t working.
I’m owning a Hercules DJ Control AIR (https://www.algoriddim.com/hardware). If I connect my MIDI to my laptop the Hercules logo shows up in djay Pro. But after that I can’t control it.
I also installed the latest drivers but it doesn’t work.
Ignore my previous message, i had suddenly hope something will happen on the Windows side but i can forget it, Windows version will NEVER be as good as the mac version…
