Could you share exact list of mixers and controllers which are compatible with Djay Pro on Windows?
You can find all supported controllers for djay Pro for Windows on our hardware list:
https://www.algoriddim.com/hardware
first test it because the windows versions sucks really hard.
Totally working, lol, have you tested the filter, flanger and loops ?
Thanks a lot. I saw it but wanted be sure whether list is updated. So that means Pioneer Ddj Wego4 compatible with Djay on Windows. Ok thanks again.
I bought and run on windows version. Totally working except i couldn’t find a way to activate “mic level” and “master level”. Probably i am missing something.
Anyway it is working well.
