Need midi support for the Numark V7 controllers and DJay Pro for OSX
Can someone on Algorriddim’s side develop a mapping to support the Numark V7s? It would be great to be able to use my favorite software with my favorite hardware. Thanks!
Yes the Midi setup detects the buttons, faders and knobs on the V7’s but it doesn’t work with the motorized platters to control the track. Plus DJay Pro needs to detect when there are 2 V7’s connected together via Cat 5 network cable.
Hi Jason,
thank you for your request.
I forwarded this internally to the development section.
Keep it up,
Thanks Jason!!! unfortunately i just purchased Djay Pro without checking to see if my v7s were supported. numark v7 and ns7 series are pretty well known controllers thought they would be compatable.
Please support the V7 - Thank you.
