(how) is it possible to play a whole playlist within neural mix? or is the neural mix app “just” a song preparation tool so that i have to load song by song and edit it…?..or will this feature be unlocked when i upgrade to the pro version?..
Hi @baker, please note the the Neural Mix Pro app is not meant for DJing or auto-mixing entire playlists. This is a tool for processing songs to extract the STEMs parts or loops. If you want to play entire playlists, then djay Pro is probably a better option for you.
I was a little bit confused because in the description it says “AI-powered stem separation, music player, and audio editor”…thanks for clearing that up!!
