Neural Mix Crossfaders Android
Reloop beatpad2
Lenovo M11
Android 14
how to turn on Neural Mix Fader on android, in the description of Djay v5.3 there is such an option but it is not possible to turn it on, is this another bug? ? what is the purpose of the MONO switch (: and where is the preview of the prepared song? is it another version for Apple? *
Hi @Jaroslaw_Szkudlarek, thanks for the details about your setup and the screenshot. Can you please also share a screenshot that shows you djay version?
Lenovo M11 It is also not possible to increase the font size in the song lists, there is no possibility to listen to the upcoming song, I have been asking for it for 9 months
This is also from this Lenovo M11
3 posts were split to a new topic: Add MIDI Commands for Auto Loop 64/128
The rest of this update works ok, even the gain cars :grin: And even without lags it’s so fast from Android observations
Hi @Jaroslaw_Szkudlarek, sorry for any miscommunication here. The community has been very busy since the 5.3 release.
Please note the the NM Crossfaders are not included in djay 5.3 per the release notes below. However, the team is working on adding this functionality in a future release.
5.3 Release Notes for Android: djay for Android » Release Notes
User Interface
  • Introducing new essential tools in crossfader section with direct access to Neural Mix, FX, or Beat Jump actions
Neural Mix
  • Introducing new Mute FX that adds optional echo tails when muting or soloing stems
  • Revamped Neural Mix FX and Loop routing allowing to multi-select stems for FX as well dynamically change the channel configuration from 2-4 stems
Crossfader FX
  • Added new “Neural Mix Echo Out” and “Neural Mix Fade” effects for the most seamless crossfades
  • Fixed gated cue play pausing on touch up
Automix
  • Now using Crossfader FX transitions
FX, Cue, Looping
  • Instant FX: added Echo Out (1 and 3/4 beats), Vinyl Stop (4 and 8 beats), Loop (1/8, 1/4, 1/2, and 1 beats), Beatmasher, and Neural Mix Echo Out
  • Manual FX: added new audio effects available via the DDJ-GRV6 integration
  • Increased maximum loop and beat jump lengths to 128 beats
  • Fixed manual FX parameters not being persisted across launches
  • Cue points now snap to closest beat when long pressing set cue in UI or on hardware controllers
Media Library
  • Fixed Match sometimes not showing results when moving crossfader very quickly
  • Fixed issues with reading metadata from certain files
Hardware
  • Improved Neural Mix pad mode on supported controllers: top row shows stem active state, bottom row exclusive solo
  • Always switch to 4 track Neural Mix when using controller with Neural Mix pad mode
Audio
  • Added mono output option
  • Improved EQ curve to be smoother
  • Auto gain: decoupled manual gain on hardware controllers from auto gain in software to allow for independent adjustments
  • Auto gain reset: double taping the gain knob first resets to auto gain level when auto gain is active, double tapping again resets to zero
  • Improved audio limiter to also be applied to pre-cue mix
  • Fixed issues with sync when song is hanging e.g. due to streamed track waiting for network
  • Fixed possible issue where songs would get stuck at end of track without jumping back to beginning
Other
  • Fixed error when loading custom samples
  • Fixed trackpad/mouse control on Android and Chromebook devices
  • Various fixes and performance improvements
Please note that our goal is to achieve feature parity for djay across all platforms. However, because core components of the apps are individually developed for each platform, such as macOS, iOS, Windows, Windows on ARM and Android, the feature sets and user experiences may vary. We are actively working to align these apps as closely as possible, both in terms of functionality and user experience, to ensure a consistent and seamless experience across all devices.
Regarding your other questions:
1. Mono: this switch turns the djay output from Stereo sound to Mono sound. This has been requested by users and is useful when connecting to a sound system that is in Mono only.
2. Song Preview: this is currently supported on Android, however the team is aware of user demand for this feature and is looking to add this in a future update.
3. Change Font Size: this is not currently supported on iOS or Android devices.
Regarding the Neural Mix Mute FX from your previous posts, please see screenshots below:
The Neural Mix Crossfaders have been added to djay 5.4 for Android. There is also now a daylight mode option.
  • Added Neural Mix crossfaders (Android)
  • Introducing “light mode”: a stunning all-white user interface option (Windows, Android)
