ipad Pro
Djay 5.3
Mixon 4
Summary of the issue:
When switching the EQ’s to Neural Mix, changes on the eq nobs aren’t mirrored on the stems in the software resulting in potential confusion on which eq nobs control which stem.
How to reproduce the issue:
Toggle the EQ switch to Neural and adjust the eq nobs on hardware. Observe the Neural mix stem levels not moving in the software.
Hi @Chris_Seymour, welcome to the Community! It sounds like you might be confusing the NM EQs with the NM Volumes. Please note that these are separate controls, separate User Interfaces and not linked to each other. These are intended to be controlled independently depending on how you prefer to use Neural Mix. Please see below for clarification. I hope that helps!
