Neural Mix Fade CFX missing for Windows
  • Device model (HP Spectre Convertible):
  • Version of operating system (windows 11):
  • Version of djay (5.3):
  • Hardware/controllers used (Pioneer DDJ 4):
Your question:
My question is regarding Crossover Neuralmix (Fade), which cannot be found under crossfader fx
Hi @Johnny_Q, welcome to the Community! Thanks for the details about your setup. Please note that the Neural Mix CFX are not currently available on Windows devices. Sorry for the misunderstanding here. However, I have passed this onto our engineering team for further consideration in a future update. Thanks!
I appreciate your consideration
Thank you!
You’re welcome @Johnny_Q
That was a disappointment…
Can you please add the new “Neural Mix Echo Out” and “Neural Mix Fade” effects in Crossfader FX for Windows too?
Sorry about that @Apos. Yes, I will pass this onto the devs.
