Hi, I’m listening to a Buddy and I’m very happy with the neuralmix. I also wanted to buy a beatpad 2 but I don’t understand if it is possible to map the commands relating to the neuralmix and how to do it and above all if it is possible to do it
Hi @guru1073,
It should be pretty easy to custom edit the built-in MIDI mapping for the Beatpad 2 to control various Neural Mix functions.
- You could change one of the Performance Pad Modes that you don’t use to Mute and/or Solo the various Neural Mix parts.
- You could also map SHIFT+Headphone Cue buttons to Toggle your EQ knobs between regular EQs and Neural Mix EQs.
- In the meantime, here’s a MIDI Mapping Guide for iOS https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
