help can’t buy or start free trial what could be the problem
Hi @babybubba,
Welcome to the Algoriddim Community forums, and thanks for reaching out about this. So we can take a closer look, could you please tell us the following:
- What device are you currently using?
- What macOS are you currently running?
- Are you able to download Neural Mix Pro fro the Mac App Store at all? If not, could you please send a screenshot of the error message you are getting when you try to download Neural Mix Pro?
Thanks in advance for the additional information.
