Same for me with most tracks. error avfaudio 2003334207. Using MacBook Air M1.
Anyone got a fix for this?
Thanks, Wayne.
Thanks, Wayne.
Hi @topgroover,
Thanks for bringing this to our attention. I’ve moved your post over to this new topic thread as it sounded like the issue you’re experiencing is a bit different from the OP. From what you’ve described, it sounds like you are receiving an error message in Neural Mix Pro.
So we can take a closer look, could you please tell us the following:
Thanks in advance for the additional information.
