Neural Mix Pro: No update since 2 years
Hi algoriddim! The Mac App Store says: Last update 2 years ago, version 1.1.1.
Do you still work on Neural Mix Pro? Will we get the new neural engine presented in djay Pro?
I would appreciate some epxtectations :wink:
And it would be great as a DAW VST/AU Plugin!
The Neural Mix engine is missing a critical setting to enable rendering all stems at the same time (most new macs have the performance for it) that way there would be no latency between changing stem volumes or enabling them
I also would like to know if Neural Mix Pro will be updated with the same neural engine in Djay Pro.
I would buy it immediately if they updated the neural engine to be like the one in Djay Pro 5. The workflow in Neural Mix Pro is unmatched, but it has fallen behind in terms of the audio quality of the stems.
Anyone had a listen at how the new Logic 11 handles stem separation in comparison?
There are plenty of videos on YouTube now. In my humble opinion, Logic is much better.
