I have a bit of an older laptop, so when I do use Neural Mix, it tends to lag, which for some reason doesn’t happen with Serato Stems (probably because i have it set to analyze stems on song load instead of on action) and that main thing really turned me off from djay because my djing has a huge stems based workflow so either add the option to do pre-analyzed stems, read serato stems files, or analyze the stems when the track loads to the deck, ik the last one would cause longer load times so just make it an option
Hi @dhruvinator, welcome to the Community. Thanks for the suggestion! I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature.
Also, if you switch the waveform display to 2, 3, or 4 Neural Mix Tracks, the analysis will happen when you first load the song.
