Neural Mix (STEMS isolation) Support for djay on Android.
Currently, Neural Mix (STEMS isolation) is not available for djay on Android. Having this feature would allow for a seamless experience between devices, making it easier for users to transition between their Laptops and mobile devices while using djay. This would be especially useful for DJs who use both platforms and want to maintain consistency in their workflow.
Thanks for the suggestion @Max_K. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
@Slak_Jaw can you sticky this to the top of the android forum for a little awareness boost?
I’m not a gambling man, and in an unrelated incident lost a finger, but I’d be willing to be another 2 :raised_hand_with_fingers_splayed: :vulcan_salute: fingers that this is the number 1 most wanted feature among android users.
Hi @Patch_ed, your best option to maintain visibility on this topic is to continue sharing feedback here. I hope that helps!
Deal, I know that it would be hard to make the neural mix available to all Androids, perhaps you can stagger it how you do on the iOS devices.
Like you must have such and such new phone, or a CPU equivalent to 2 GHz etc to do 100% stem separation.
And being that meta is built off of the Android platform, it would be a double whammy and the quest headsets, at least the 3/3s could benefit as well :grin:
