Neural Mix Volume vs EQ
i noticed in the midi mapping that i can choose to asign a button to either Neural Mix Volume or Neural Mix EQ. This option exists for all 2,3 and 4 band and for each drums, harmonics and vocal etc
what is the difference betweenNeural Mix Volume or Neural Mix EQ?
Hi @DJ_STUB,
Glad to see you in the community again!
Neural Mix Volume simply increases and decreases the volume of the active Neural Mix stem (Vox, drums, etc).
Neural Mix EQ adjusts the EQ curve of the active Neural Mix stem.
Feel free to play with the different modes to see what suits you best!
