- Device model: iPad Air (2024)
- Version of operating system: iOS 17.6
- Version of djay: 5.1.2
- Hardware/controllers used: Xone K2
Summary of the issue:
After restarting the app, most settings persist, as is expected on iOS apps. However, the Neuralmix mixer settings do not. Specifically, if 4 stems are selected, then this is reset back to 3 stems on restart.
How to reproduce the issue:
Set Neuralmix mixer to 4 stem mode. Restart app. Neuralmix mixer settings are reset back to 3 stem mode.
Thanks for the details about this issue @wasabidj, but I believe you shared the View Settings video instead of the Neural Mix Mixer video. Please share the correct video. Thanks!
@wasabidj I tested this on 5.2.1 and the 4 STEMs Neural Mix Mixer remains when I do an app restart. Please update to 5.2.1 and confirm if that solves your issue. Thanks!
That should have read 5.2.1.
@wasabidj please retest. I was unable to reproduce on 5.2.1.
Here’s another video, not sure what else I can do…
Thanks for the additional video @wasabidj. Very strange. Please try updating to the recently released 5.2.2 to see if that solves your issue. I tested several times on 5.2.1 and 5.2.2 and it remembers my 4 STEMS Neural Mix Volume selection upon restart.
Hi @Slak_Jaw
I tried updating and rerunning the test and I get exactly the same behaviour.
I’m running the test on a clean install of Djay with no additional configuration.
Hi @wasabidj, please try loading and playing a track on the Deck before preforming the restart.
UPDATE: okay, I’m now experiencing some inconsistency here. I’m running 5.2.2 and the NM Volumes are staying on 4 STEMS mode when restarting. If I change them to 2 or 3, they return to 4 when restarting. I have shared this with engineering for further review. Thanks!
