Your question:
What do I need to do in order to activate my NEURA MIX on my DJ PRO. Did subscribed already to tidal di extension
Neural Mix will only work on devices that are capable of the processing involved.
As you have not given details of which device/OS/hardware/controller you have, then I have to guess that your device is not capable.
- List item
This is the screenshot. I subscribed already to DJ extension but still cannot access this feature. Do I need to do something else? Thanks
Can you show screen shot of your tidal account. Will look something like this
Hi @Norman_Tinio, thanks for the screenshot. As requested above, please provide details about your setup. Note that you need to be running djay 5.1.5 or higher for Neural Mix to work with TIDAL.
