neural on off button but with a delay (smooth 100% to 0%)
Hi guys, I had some times to compare serato stems and djay neural work. In serato when you press on my rane one a button premapped by default for remove for example the instrumental part u can hear a smooth delay from 100 to 0%. I think this is great because is really near when i set in djay a mapping of neural eq on my rane one eq.
Will be great if this smooth delay will be implemented in future realease because when you are using external mixer set up like with my reloop elite, u can work on neural only with button and there are today no possibility to have a little smooth delay from 100% to 0% because is immediate cut.
Hope this function will be implemented, will be great if it’ll be insert in settings so anyone could decide if need or not
Carletto Dj
Thanks for the suggestion @carletto_dj. Can you please try to capture a short video of this works with Serato, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? I want to make sure this is clearly communicated to our dev team. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
