Neural Vocal Echo Out stops working
  • Device model (e.g. 2020 iPad Air 4th Gen): 2024 MacBook Air
  • Version of operating system (e.g. macOS 14.4.1): MacOS 14.6.1
  • Version of djay (e.g. 5.1.2): 5.2.4
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DDJ-FLX4
Summary of the issue:
Neural Echo Out 1 works fine for about an hour and then for some reason it stops ‘echoing out’ and just cuts the vocal track without the echo effect.
How to reproduce the issue:
DJ for about an hour or so straight and use the Neural Echo out effect a couple of time throughout the hour and then after about an hour or so it will stop ‘echoing out’ and just cut the vocal without the echo effect.
I hope this bug can be fixed cause it’s happened to me a couple of times on my DJ set already! Eek! Thanks for your attention and time on this. Hope ya have a great day!
Hi @megaman24, thanks for the details about your setup and the issue. Since this is repeatable, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? This will help to communicate the issue to our engineering team so they can try to replicate it on their hardware. Thanks!
Hello! It’s been more than 10 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
Hey! Sorry for not not being able to recreate the bug, I’ve been out of town but will be back next week and can recreate the bug. Thanks! :pray:
Sounds good. Looking forward to reviewing the video. Thanks!
