Neuralmix automix options
Hi, great work with the stems isolation but when I use it in automix, it always cuts the vocals and mixes the instrumental.
I would like to do it the other way around, to fade in the vocal into the other track instrumental and then mix over the instrumental.
Would be nice to have both options automated because for now I have to do it manually :slight_smile:
keep up the good work.
Hi @Vasco_Martins,
Thanks for your kind words of support! Just to be sure I fully understand your feedback, are you talking about when you are using the Neural Mix Automix transition specifically? I’ve included a screenshot below:
Looking forward to your reply!
Hi, Yes,
When using that option the automix always fades out the “Acappela” and mixes the “Istrumental”
Would be nice to have the option to mix the “Istrumental” and have the “Acappela” of the ongoing track to overlap the instrumental of the next track for a couple of seconds or vice versa.
Thanks for your feedback about this! I’ll share this with our Dev Team for further review, and keep this thread updated with any news. :notes:
wow, that’s really nice to know… thank you for taking my request in consideration.
Best regards
