New feature! Can now select EQ on one track and Neural mix EQ on the other!
Is there anyway of finding our what improvements, tweaks, features are being added??
I’ve just discovered that we can now have one track using normal EQ and the other using Neural Mix EQ - this was not possible a month or so again (when you changed the EQ type it automatically applied to both tracks) - good work algoriddim!! But would love to know about these improvements as soon as you make them
Just by way of an update for anyone else using this feature - on 4 track mixing, track 1 and 3 EQ type is the same and track 2 and 4 is the same e.g. either Normal EQ or Neural EQ
