i have the brand new ipad pro. it works well with the adaptor, but its slightly thinner in size. is there any type of adapter wrap to make it sit well in the slot? perhaps a bootie or something to make it wider and thicker
The iDJ Pro should come with Velcro strips which you can place underneath the iPad to boost its height and ensure a snug fit.
If you don’t have any, I’d suggest placing a piece of thick fabric underneath instead.
I have never seen an iPad with enough storage for me to dj with.
Um. Not sure of that
What slot?
Hi Antonia Valenti,
finding an Adapter would rather be a Hardware problem I assume, have you contacted Numark about your issue?
I forgot to mention I have the Numark idj Pro
