Please algoriddim change the screen setup for djay 2 on a beatpad!
what I am missing so much is the possibility to see which fx I got selected. I always need to have the Fx tab open on both decks just to see which fx I got selected, but I don’t need the controls (got them on the beatpad) blocking half the waveform. I wish to see somewhere SMALL which Fx is selected.
Please ad this Warren, it would make djay on the Beatpad even smoother!
Hey, you Guss Finale did it!!!
Thanks for the new layout! Gotta get used to it though… But I like it.
Unfortunately I need to report a little bug already.
The fx selection started to act weird after a while. You couldn’t see what fx you had selected on one track. Whatever I did I couldn’t get to appear again. The only way to see what I had selected was to tap on the display and have the selection menu pop up. I couldn’t restart as I was in the middle of performing…
I hope you can fix this little bug, because otherwise you did a fantastic job with djay!
Hey, you guys Finally did it!!!
The fx selection started to act weird after a while. You couldn’t see what fx you had selected on the left track. Whatever I did I couldn’t get to appear again. The only way to see what I had selected was to tap on the display and have the selection menu pop up. I couldn’t restart as I was in the middle of performing…
Yes it’s a great, great improvemen!. I can also verify the bug in displaying the name of the effect, it sometimes dissapear totally, but i’m sure they’ll fix it
