New mapping shortcuts for Djay2 for Ipad and Reloop beatpad
Hello,
I’m a Djay2 for Ipad with the Beatpad controller from reloop.
I think it would be nice to add some shortcut using the shift botton :
For exemple with the combination Shift + Fx on : display the fx window on the screen, exactly like the combination shift+ sample that enable the display of the sample window.
Shift + instant fx for display the intant Fx window
I hope you can do that on the next update.
Best regards for you guys.
Ricardello
Thanks for posting your idea.
Plus add a way to see which fx your on whiteout the fx window being open!
