If I’m playing a spotify playlist with automix, is it possible to AUTOMATICALLY add new songs added to that playlist, to be played with automix?
Hi Breakers Arg,
Only while using the Spotify radio option, audio is being played completely automatically.
If Spotify Radio is selected as Automix setting, starting the Automix will lead to an automatical playback of Spotify tracks.
Lukas, what do you mean by “…the Spotify radio option…”?
In Spotify, I go to playlist radio and select button play (in spotify)
and then?
