NEW UPDATE - DJAY NOT WORKING MAC IOS
I’m having problems with Djay, not Djay Pro. it’s not working since the recent update. How do I fix the issue?
Djay is not in the apps anymore, only Djay Pro. I have already paid for the app.
Solution?
Having the same issue. I’ve paid for the app and have a gig in a coupe of days. Alogriddim gonna fix this?
Please kindly provide more information so we can better assist you.* Which device do you have?
* Which OS version is running on your device?
* Which djay version are you using? (If you are using an iOS/ Android Device: Please tap the gear icon and scroll down to determine the version number.)
Have a similar issue and Algoriddim for some reason has not responded… Also, songs in the djay library not visible!!!
