No bluetooth option?
Sorry for the very beginner question. I’m using my macbook for mix for my dance studio. The studio has standard speaker (bluetooth enabled or stereo input options). When I connect my macbook to the speaker via bluetooth, everything plays except Djay pro. Is bluetooth not an option in this case?
I believe you need to go into the settings “audio” and pick which speaker. Keep in mind, you may have latency using Bluetooth speakers.
It definitely should work.
In Main menu => Settings => Audio devices, set Mixer mode to Internal and Main output to bluetooth speaker in question. Pre-cueing could be set to none, if it’s not needed.
If you’re planning to use Auto Mix, don’t worry about latency. It’s not an issue in this case.
Thanks again for the help @t3ks1st0
