No Connection
my iPad 2 will not connect to the IDJ Pro. I have IOS 9.2.1 and I also purchased the DJ2 APP. when i plug it in the IDJ it does nothing. My friends IPad works fine inside it with no problem.
Hi Noel Deas,
thank you for your post. Is your iPad charging if connected to the iDJ?
could you tell us what iPad your friend is using? Please note that the iPad 2 is fully supported by the iDJ Pro.
Are you experiencing connection dropouts with your iPad when you are connecting it to a regular charger?
No it is not charging
