No Match Results Active Deck
  • When Match is set to Active Deck it always displays “No match results for current songs” If the song in the Active deck is dropped into Match using custom it displays results.
  • Only time it works is with Tidal. Local, Spotify & Beatsource do not work.
Vid attached.
Hi @Mikie-B, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
Thanks for the video - this is very helpful.
  1. What source are you using for these songs (local music stored on device, streaming service, etc.)?
  2. Does the “Match Active Deck” option work if Deck 2 is playing and audible on the master output?
Sorry about that. Some questions were answered in the orginal post, will answer below.
System:
Processor 13th Gen Intel(R) Core™ i7-13620H (2.40 GHz)
Installed RAM 16.0 GB (13.7 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
OS:
Edition Windows 11 Home
Version 25H2
Installed on ‎8/‎23/‎2025
OS build 26200.7840
Experience Windows Feature Experience Pack 1000.26100.291.0
DJay Pro Ver: 5.6.2
  1. What source are you using for these songs (local music stored on device, streaming service, etc.)? Tested with Local, Spotify, Beatsource and Tidal. Only Tidal produced results.
  2. Does the “Match Active Deck” option work if Deck 2 is playing and audible on the master output? Only when using Tidal. See video link for visual.
Video of Active Match: 01.03.2026_18.13.57_REC
Hope this helps.
Thanks for the additional info and answers to my questions @Mikie-B. I was unable to reproduce this on my Windows setup - Match->Active Deck is working as expected. I’ll need to pass this onto our engineering team to see if they can reproduce this. Can you please upload your second video here directly? Thanks!
Sure can. Thanks for your help!
You’re welcome! Thanks for the video.
Hi again @Mikie-B, our engineering team was able to reproduce this from within the My Collection Source only. If you load the tracks directly the specific streaming service source (Beatsource for example) or from within the My Files Source, does Match->Active Deck work?
Yes, as shown in the latest video, all streaming services we use (Spotify, Beatsource, and Tidal) work correctly with Active Match on Decks 1 and 2.
The My Files Source (Explorer) has not been tested, as we currently do not have any tracks loaded in that location.
Hope that was the answer you were looking for.
Thanks for the additional info @Mikie-B
Been awhile checking in for any updates?
Thanks,
Mike
Hi @Mikie-B, we have no updates to share.
