hi updated my djay pro to the latest version and now i cant talk on the mic coz it dont come out with the music. so arrrrrgggghhh, how can i fix that? im a pub djay and need my mic to flex with my crowd.
Bizzo…
Bizzo…
Hey Bizzo,
can you tell us which mic you are using and how you connect the mic to djay Pro?
Thank you in advance.
Cheers,Lukas E.
I’m using a Hercules dj4set controller, used to work fine before and all of a sudden no mic output with the music, i connect the mic through the controller.
hi
anyone know how to setup midi mapping for the synq audio dmc 2000?
