this problem just started today 1/4/17.Unitil yesterday I could mix my own playlists from Spotify on djay Pro on iMac , what 's going wrong?
As Philippe Perras pointed out, the playlist tab can be found in the lower menu bar, please see screenshot above.
Cheers,Lukas E.
Look at the 20 others posts with the same problem or look here :
Algoriddim i think you will need to do a pin post with that.
