Hi all,
after a couple of month I pluged my Vestax Spin into my mac (10.8.2) but Djay (4.1) doesn’t recognise it. This is the first time it does that. Only the red light for power goes on.
Can anybody help me.
Thank you
Hi all,
Thank you
Hi Patrik,
I recommend trying another USB cable or port on your Mac.
Hi Warren,
thanks for the repley.
I tried every USB port and 3 differend USB cables but still, nothing happens.
The red light for power goes on so the cable seems to work fine, is there a new driver I don’t know anything about?
Thanks in advance for any help
I had the same problem! After some restarts it works fine. Going to try it tomorrow. Going to give a feedback if it happens again.
