No sound from iMac after connecting DDJ-FLX4
Hi, I have an iMac and used a DDJ200, it all worked fine.
I have now switched to the DDJ FLX4. Everything is ok, all the lights are on etc. except that there is no sound from the computer. I can load songs and play / pause using the FLX4 controller but there is no sound from the computer.
If I close DJay Pro and launch Rekordbox, everything works fine.
Is that a known issue?
Hi @Hans_de_Vries, sorry to hear you’re having issues.
  1. Please provide specific details about the Mac laptop you are using.
  2. What macOS version are you using?
  3. What version of djay Pro are you using? Do you have a paid djay Pro subscription?
  4. How exactly are you connecting your computer to the FLX4 (ex. directly with USB-C cable, through a USB Hub or adapter, etc)? Please provide photos of all the cabling, USB Hubs, etc. if possible.
  5. Is the FLX4 also connected to power or are you running it off the laptop bus power?
  6. Do you have speakers connected to the FLX4 or are you trying to play audio through your laptop speakers?
  7. Please provide a screen shot of your djay Settings>Audio Devices.
  8. Please also provide a screen shot of your djay Settings>MIDI Devices.
Hi @Hans_de_Vries did that solve your issue?
Solved
Unlike the DDJ200 you need to connect the speakers using an RCA to minijack cable
Great. Thanks for letting me know @Hans_de_Vries
