No sound from sampler
I’m using DJ 2 with a Reloop beatpad 2, after installing the latest version of DJ my sampler has stopped producing any sound when connected to the beatpad,if disconnected the sampler on the iPad works fine.
Beatpad 2 is less than a week old
Hi, I saw there was a similar post. Perhaps you can get some good advice here: http://community.algoriddim.com/algor…
Cheers!
I tried this and it worked,
Thanks for the heads up.
Cheers Gary
