No sound output on 2nd deck after automix is turned off…
  • iPad 10th gen 2022
  • iPadOS 17.5.1
  • Version of djay 5.1.7
  • Hercules Inpulse 500
Hello all, the issue I’m having is that when I turn off automix, the second deck will not put out any sound in classic or pro…
While a track is in play on one deck during automix, if I turn automix off and I then switch to pro or classic I’m having trouble getting the second deck to output any sound when I manually press play on my controller. I’m having to restart the app to get it to play properly. Any help with this issue would be greatly appreciated…
Hi @NoDJ, try moving the Crossfader into the middle position. Please note that Automix moves the onscreen Crossfader independent of the hardware Crossfader. So the onscreen Crossfader is probably on the opposite deck.
Excellent! That’s exactly what was wrong! The onscreen crossfader was on the other deck. Thanks @Slak_Jaw!
You’re welcome @NoDJ
