sono riuscito parzialmente a mappare hercules RMX2 con Djay. Ora però non riesco a mappare le luci della consolle. Qualcuno può aiutarmi???
You can try to enable the “MIDI Out” under “Advanced” options.
If this doesn’t work, then this means that the lights cannot be controlled/mapped via MIDI learn.
excuse in the post I can see the screen but I do not see written MIDI Out Under “Advanced” options.
nopn can not understand which key you have to click for the lights from the console version rmx worked …
