Why can’t I scratch on a deck when its playing? I use Hercules RMX console. I’ve tried everything, I think.
The jogwheels of your controller are not touch-sensitive. So, if you want to use the jogwheels for scratching, all you need to do is press “pause” on the turntable.
The scratch while the deck is playing works when the controller is connected to my iPad/iPhone/virtual dj/android tablet it just won’t scratch while playing on my MacBook on djay pro software
