I’d like a notification when a new suggestion is made. I’m sure suggestions would get more upvotes if we were notified of them (I only check this section when I’m given a specific link in other posts tbh).
An RSS feed would be a good idea for this, but it would have to be supported by the forum framework used here. RSS may not be up to date, but it works very well.
A follow option for categories might be even simpler, and would probably lead to increased engagement.
However, my preference would be a weekly activity email, then its not reliant on you actually being logged in.
Thanks for the suggestion. I have forwarded this to the dev team for consideration.
Hi @N_C, so it turns out this is already possible. Simply navigate to the Suggestions category and hit the Notification Bell and select Watching.
Aha! You should publicise this - sure you’d get more engagement.
