Can you now focus on
saved loops
quantised hot cues
shortened loops
mixon djay pro iPad mapping (must be driving users nuts not to have a fully functioning map)
saved loops
quantised hot cues
shortened loops
Hey Dysfunk DJ,
Cheers,Lukas E.
Good to hear you guys are getting on with it. Kind of put me off buying a mixon with the map as is. For sure djay pro has the best algorithm for syncing tracks, nothing else keeps funk, old Skool and accapellas locked like this software. With saved loops, tighter cue point juggling sync it would be rock solid. Plus with Spotify nothing comes close. More sample packs would be good too. And a money earner for you, as I would imagine for a few $ most if not all will buy
