NS6 Crossfader issue
YOUR QUESTION:
  1. The crossfader in combination with my NS6 (on Windows 11 25H2) doesn’t work properly: all of a sudden when fading from deck 1 to deck 2 it doesn’t fade out, while going from deck 2 to deck 1 it does fade out. I’ve given it a try on Serato DJPro 2.5.1 and it does function properly. What to do?
Hi @Sparrie77, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Since this sounds repeatable, can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
Sure, I made one, but I can’t upload it because I’m a new user :frowning:
I have already changed your permissions so you can upload your video.
Thank you so much for the quick replies!
You’re welcome @Sparrie77. Thanks for the video.
  1. Can you please share a screen recording so I can see what is happening in djay?
  2. Please also confirm your djay version and Numark NS6 firmware version.
  3. Also, what crossfader curve settings are you using on the NS6 and within the djay settings?
Forgot about the versions, sorry:
Numark NS6 version 1.0.3(k1) & djayPRO 5.6.4
The curve settings are default on both the NS6 and in djayPRO (both linefader and crossfader)
Thanks for the video and additional setup details @Sparrie77.
  1. Please check the Crossfader Curve dial and assignement switches for DECK A and DECK B
  2. Please also share screenshots of your djay Settings>Audio Devices and Settings>MIDI Devices.
Thank you.
  1. Please select Reset to Defaults at the bottom of the Audio Devices settings.
  2. Make sure the DECK A switches are both set to L and the DECK B switches are both set to R
And a miracle happened: after reseting to default and flicking the switches back and forth all is working again! :smiley:
Thank you so much for your help!
You’re welcome @Sparrie77. Glad we were able to sort it out. Happy to help!
