Numark DJ2GO with DJAY 2 on iphone 4 S does not work! Why not?
Hello, Good night. I have Numark DJ2GO and I have an iphone 4s and I recently bought and installed DJay 2 on my iphone to be able to control the DJay 2 with DJ2GO because the screenshot of my iPhone is too small to be able to easily touch with my fingers in all functions that DJAY 2 has.
The problem is that I have already connected the DJ2GO the iPhone through an OTG cable and does not work because the DJAY 2 does not detect the DJ2GO!
What is strange is that I’ve seen several videos on internet of DJays using the DJAY2 with DJ2GO on the iphone! How is this possible?
Can you help me to do the same?
Thank you and congratulations for your great work!
Best Regards,
Luis Fontes or DJay Phil Alive
See below:
"I am sorry to tell you but the Numark DJ2GO is not supported by iOS. Sorry for the misunderstanding, the iDJ 2 GO by ION is supporting djay 2 for the iPhone, see:
https://www.ionaudio.com/products/det… "
thank you for your post. Could you tell us which iOS version and djay 2 version you are using?
Thank you in advance.
is the DJ2GO being displayed as detected midi device if you open the djay 2 “Preferences” and click on “Midi”?
Hi DJay Phil Alive,
https://www.ionaudio.com/products/details/idj2go
Good Niight! Thank you for answer my post!
My IOS version is 9.2.1 and Djay 2 version is 2.8.1.
I really want to solve this problem and I really need your help!
Thank you and keep your excellent work!
Best Regards,
Luis Fontes
DJay Phil Alive
Good afternoon. Thank you once again for helping me solving this problem!
I opened the DJAY 2, I went to preferences and then selected the midi tab and in this tab, even though it appears to say that was found or detected 1 midi device does not appear the name of the device, and even after pressing the “rescan for midi controllers” button, nothing happens and nothing changes!
I’m getting increasingly annoyed with this.
Help me please to understand what is causing this problem.
Thank you.
Best Regards,
Luis Fontes
DJay Phil Alive
IPHONE 4 AND ANY PHONE DEVISES WILL NOT WORK BECAUSE IT’S NOT MIDI DJ CONTROLLER S ARE AUDIO COMPONENTS THAT ARE MIDI NOT APPLETS BUT NUMARK IS PC & MAC COMPATIBLE PLUG N PLAY TRY IT OUT
