How do I get the Numark dj2go2 controller to work with my ipad. I downloaded & purchased the newest version of djay for my ipad. I have it connected to a powered usb hub, the ipad recognizes it, but none of the buttons work on the controller.
Thank you.
Dennis Falcone
Hi Dennis,
Can you tell us the exact djay version you are using?
Cheers,Lukas E.
Hey Dennis. The powered usb hub needs to have enough power first of all. The controller uses 1amp so make sure your hub can supply at least that much. Secondly, you need to have a usb cable that can transfer the (midi) “data” which requires a special adapter. Look for the lightning to usb camera adapter (either 1st party or 3rd party should work) and plug the data cable from your usb hub into the adapter/dongle. This worked for me.
