Numark FX Platinum "second layer" of pads mapping
IOS 15 or higher
Windows 10
I’d like to know if there’s a way to map something like second layer of pad modes on Numark Platinum FX. I mean, something like “SHIFT + AUTO LOOP mode” = “PAD FX mode”. And then, map the performance pads underneath it to work as Pad FX 1 to 8, instead of the Auto Loop pads 1 to 8.
Many controllers, like the NS4FX, FLX4, DDJ 400, DDJ SR, DDJ SB3, Hercules 500, etc. have two possibilities for each pad mode button, you just have to click SHIFT + PAD MODE to access the second pad mode…
Is it possible to map something like this on Platinum FX?
Thanks in advance.
Hi @Carlos_Alexandre_Cam, this is currently not possible with this hardware as it does not send different MIDI messages from the pads when selecting the new pad mode.
