Hey! Is there a way to have the Numark iDJ Live for iPad/iPod Touvh turntable compatible with the Djay software on a Macbook Pro? I thought maybe the Djay remote app would work with the turntable but it doesn’t (unless theres a setting that I’m not aware of). Basically I want to use that turntable to control the software on the Macbook Pro. Thanks!
Hi Luis,
iDJ Live is only compatible with iOS devices.
