Can’t use my iPad Air2 on this midi mixer any ideas about mapping anyone?
I don’t have a Mac I have an Acer Aspire notebook .
Algoriddim only supports dedicated ios controllers.
Just brings us round to
- consider what features your looking for in software to your desired work flow
- consider your budget
- purchase a controller according to the software you want to use with your desired work flow
For example I realised that djay 2 had all the features I was looking for, so I worked out my budget and worked out through research that the beatpad 2 would be the best controller for me.
Easy as 1,2,3
I don’t think the mix deck is compatible with djay for iPad
Hi thanks DJ Ivan was just wondering was there any other way around it for iPad seeing as most DJs I know would rather iPad .
Hi thanks for reply but I think I should clarify : I have Serato and use it . It’s just as a back up I’v used IDJ PRO a great mixer with DJPro using an iPad . So easy and versatile using my own music files also Spotify and iTunes to , I just feel iPad is the way forward . Most new laptops are detachable.
