Are there any plans to natively support the new Numark Mixtrack Platinum FX?
Mine arrived today and was hoping to avoid mapping it myself.
Hi Greg, The Platinum FX is on our agenda. Thank you for getting in touch. We will let you know if there are news regarding the implementation.
Hello
Any update as to when you will support the Numark Mixtrack Platinum FX ? How does it work if you manually configure through MIDI learn ? Any tips ?
Thanks in advance
Michael
